20 years agoHow to specify 10Mbps and 100Mbps
Hi all, How and where can I specify which LAN connection I want to use: 10Mbps or 100 Mbps; full duplex or half duplex? I am using NIOS II 5.1 'simple socket server example' on NIOS II ...
20 years ago --- Quote Start --- originally posted by slacker@May 23 2006, 10:00 AM it's not just in the example or even, really, a part of the example. it's in the driver code for the 91c111. <lan91c11_comp_dir>/ucosii/src/altera_avalon_lan91c111.c
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15535)
--- quote end ---
--- Quote End --- Thanks slacker. In which file and what change should I make to force the connection for 10Mbps Full Duplex mode (as I observed my custom board is malfunctioning at 100Mbps mode). Sincerely,
