20 years agoHow to specify 10Mbps and 100Mbps
Hi all, How and where can I specify which LAN connection I want to use: 10Mbps or 100 Mbps; full duplex or half duplex? I am using NIOS II 5.1 'simple socket server example' on NIOS II ...
20 years ago --- Quote Start --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15504)</div> --- Quote End --- There's some registers in the LAN91C111 that you'll have to set. Go to SMSC's site and download the datasheet for the chip. The driver that ship with the Nios dev kit sets it to auto-negotiate the speed, so just search for where it does that and change it to use whatever speed you want. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15513)</div> --- Quote End --- Thanx a lot. But can u tell me by default, what line (mbps and duplex method) is used in simple_socket-server example? Sincerely,
