20 years agohow can I run uclinux on EP2S60 DSP board
My board is ep2s60 dsp board.Currently NIOS II linux v1.4 doesn't support the board.At present,I can download the kernel to the board,but I fail to download the filesystem to the board.when I want to build a filesystem,an warning appears,the warning is "Total amount of memory available: 0 k" .If I want to run uclinux on the board.what should I do?I'm really confused!who can tell me ?thanks.
It may be problem of the MTD partition config.
You should try out Initramfs on a new board first. The rootfs is linked into kernel. http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) Then you can modify the MTD config, mount jffs2 etc. Chech the prior post from marc. http://forum.niosforum.com/forum/index.php...c=3023&hl=jffs2 (http://forum.niosforum.com/forum/index.php?showtopic=3023&hl=jffs2) update map in the file linux-2.6.x/drivers/mtd/maps/altera.c - Altera_Forum
I have put the uClinux via the microtronix Windows tools onto it - and when I get that message I ignore it and manually check to see if the image is less than 2Mb. If it is - it usually works.
However I highly recommend hippo's buildroot system system using Linux - once set up it is much easier to use / customise and understand than the pre built system.
