20 years agohow can I run uclinux on EP2S60 DSP board
My board is ep2s60 dsp board.Currently NIOS II linux v1.4 doesn't support the board.At present,I can download the kernel to the board,but I fail to download the filesystem to the board.when I wan...
20 years agoIt may be problem of the MTD partition config.
You should try out Initramfs on a new board first. The rootfs is linked into kernel. http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) Then you can modify the MTD config, mount jffs2 etc. Chech the prior post from marc. http://forum.niosforum.com/forum/index.php...c=3023&hl=jffs2 (http://forum.niosforum.com/forum/index.php?showtopic=3023&hl=jffs2) update map in the file linux-2.6.x/drivers/mtd/maps/altera.c
