20 years agohow can I run uclinux on EP2S60 DSP board
My board is ep2s60 dsp board.Currently NIOS II linux v1.4 doesn't support the board.At present,I can download the kernel to the board,but I fail to download the filesystem to the board.when I wan...
20 years agoI have put the uClinux via the microtronix Windows tools onto it - and when I get that message I ignore it and manually check to see if the image is less than 2Mb. If it is - it usually works.
However I highly recommend hippo's buildroot system system using Linux - once set up it is much easier to use / customise and understand than the pre built system.
