14 years agoHELP:how to remove these timing critical warning
I get some critical warnings for timing,when I make the TSE project.
I want to implement a 150MHz nios II system of TSE transciever, and I almost finish the hardware of nios II with the DE4 board. but I get the critical warnings,how to solve it ,help me please.thank you so much .. I attach the quartus II archive file,Please help me as your convenience! the Qsys componets like: CPU--> -->onchip memory -->pipeline bridge 1----> cpu peripherals -->pipeline bridge 2----> IOs -->pipeline bridge 3----> ext_flash -->TSE_MAC -->SGDMA-tx/rx -->descriptor memory thanks again!!3 Replies
Look for the top failing paths report in Timequest to determine where you need to add more pipelining.
A typical path that needs a pipeline bridge is the one between the Nios CPU masters (data and instruction) and the CPU's JTAG debug slave interface. Going over 100MHz on a Nios II system on a Cyclone FPGA is possible, but requires some patience... - Altera_Forum
first thanks for your help.
yes I place a pipeline bridge between cpu and jtag. as : cpu <----->pipeline bridge <---->[jtag uart,sysid,timer,..] but these critical warning are for the TSE. so it is a little complicated and difficult to me. --- Quote Start --- Look for the top failing paths report in Timequest to determine where you need to add more pipelining. A typical path that needs a pipeline bridge is the one between the Nios CPU masters (data and instruction) and the CPU's JTAG debug slave interface. Going over 100MHz on a Nios II system on a Cyclone FPGA is possible, but requires some patience... --- Quote End --- - Altera_Forum
You should look at the top failing paths instead. It is in the "Macros" category in Timequest.
If the failing paths are inside the TSE itself, then there isn't a lot you can do, except decreasing the frequency. If it is between the TSE and something else, then there may be something you can do.
