14 years agoHELP:how to remove these timing critical warning
I get some critical warnings for timing,when I make the TSE project. I want to implement a 150MHz nios II system of TSE transciever, and I almost finish the hardware of nios II with the DE...
14 years agoYou should look at the top failing paths instead. It is in the "Macros" category in Timequest.
If the failing paths are inside the TSE itself, then there isn't a lot you can do, except decreasing the frequency. If it is between the TSE and something else, then there may be something you can do.
