20 years ago
Help! "NiosII download failed!"
I build a cpu and download it into DE2 board,and when I run the "hello_world" to make sure whether my cpu is working normally,it occurs as follow:(I use the Nios IDE shell)
[SOPC Builder]$ nd hello_world.srec
# 2006.07.19 12:40:41 (*) nios2-gdb-server --tcpport=2342&
# 2006.07.19 12:40:41 (*) downloading hello_world.elf
# 2006.07.19 12:40:41 (*) nios2-elf-insight --command=/tmp/hello_world_setup.gdb
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
    Now,it can download ,but when verify ,errors appear!
    Can anybody help me? Thanks in advance!
    Pausing target processor: OK
    Reading System ID at address 0x00102098: verified
    Downloading 00800020 ( 0%)
    Downloading 00810000 (89%)
    Downloaded 72KB in 0.9s (80.0KB/s)
    Verifying 00800020 ( 0%)
    Verify failed between address 0x800020 and 0x80FFFF
    But I build a new nios-cpu ,it works well.
    The errors didn't occur again,but I still don't kown the reason wky the first one did not work !
    Could anyone help me?
    --- Quote Start ---
    originally posted by wallace@Jul 21 2006, 08:14 AM
    but i build a new nios-cpu ,it works well.
    the errors didn't occur again,but i still don't kown the reason wky the first one did not work !
    could anyone help me?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17052)
    --- quote end ---
    --- Quote End ---
    Hi i&#39;m getting started now with a stratix II (EP2S60F1020C4) and i had the same problem :
    Verifying 03000020 ( 0%)
    Verify failed
    Leaving target processor paused.
    I solved it by downloading an the board the standard.qpf file that i found i the directory:
    altera\kits\StratixII_DSP_Kit-v1.1.0\Examples\HW\NiosII\example_designs\vhdl\standard
    I have downloaded this file without compiling it.
    I started Nios II IDE and runned a sample project unchecking Validate Nios II System ID before software downolad.
    Everything works fine now.Good Luck and sorry if said uncorrect things but i&#39;m not so expert as you are! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
    --- Quote Start ---
    originally posted by buca+jul 25 2006, 12:50 am--><div class='quotetop'>quote (buca @ jul 25 2006, 12:50 am)</div>
    --- quote start ---
    <!--quotebegin-wallace@Jul 21 2006, 08:14 AM
    the errors didn&#39;t occur again,but i still don&#39;t kown the reason wky the first one did not work !
    --- quote end ---
    --- Quote End ---
    Verify failed
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17073)</div>
    [/b]
    --- Quote End ---
    Hello!
    but I must download the system which I bulid according my requires.Is there something that I haven&#39;t paied attention to?
    --- Quote Start ---
    originally posted by wallace@Jul 19 2006, 06:20 AM
    now,it can download ,but when verify ,errors appear!
    can anybody help me? thanks in advance!
    using cable "usb-blaster [usb-0]", device 1, instance 0x00
    pausing target processor: ok
    reading system id at address 0x00102098: verified
    downloading 00800020 ( 0%)
    downloading 00810000 (89%)
    downloaded 72kb in 0.9s (80.0kb/s)
    verifying 00800020 ( 0%)
    verify failed between address 0x800020 and 0x80ffff
    leaving target processor paused
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17007)
    --- quote end ---
    --- Quote End ---
    There are so many reasons for the Verify fail, that is why it is so popular.
    Here are a few that I have seen
    1. Bad memory interface, physical board problem
    2. Timing issue with memory
    3. Lack of non-volatile memory. This confuses processor.
    If you have problems with downloading programs from the IDE, I suggest to try reconfigure your FPGA with a "simple" test design that is a sub-set of your design. For example to isolate if your problem is SDRAM or SRAM, try to use/add onchip_memory to run hello world from. If the onchip_memory program runs, but loading the program to SDRAM/sram still fails, I would take a closer look at the memory timing or phase setting.
