20 years agoHelp! "NiosII download failed!"
I build a cpu and download it into DE2 board,and when I run the "hello_world" to make sure whether my cpu is working normally,it occurs as follow:(I use the Nios IDE shell) [SOPC Builder]$ n...
20 years ago --- Quote Start --- originally posted by wallace@Jul 21 2006, 08:14 AM but i build a new nios-cpu ,it works well.
the errors didn't occur again,but i still don't kown the reason wky the first one did not work !
could anyone help me?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17052)
--- quote end ---
--- Quote End --- Hi i'm getting started now with a stratix II (EP2S60F1020C4) and i had the same problem : Verifying 03000020 ( 0%) Verify failed Leaving target processor paused. I solved it by downloading an the board the standard.qpf file that i found i the directory: altera\kits\StratixII_DSP_Kit-v1.1.0\Examples\HW\NiosII\example_designs\vhdl\standard I have downloaded this file without compiling it. I started Nios II IDE and runned a sample project unchecking Validate Nios II System ID before software downolad. Everything works fine now.Good Luck and sorry if said uncorrect things but i'm not so expert as you are! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
