20 years agoHelp! "NiosII download failed!"
I build a cpu and download it into DE2 board,and when I run the "hello_world" to make sure whether my cpu is working normally,it occurs as follow:(I use the Nios IDE shell) [SOPC Builder]$ n...
20 years agoI am using the DE2 board.
I faced the same problem if I instantiated the cpu in VHDL. However , it work fine if I instantiated the cpu in Verilog. Why is it so???? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
