20 years ago
help me,save my memory
hi!
my application use more memory in the nios than arm platform
I use the objdump print as follow:
[root@localhost pppd]# nios2-elf-objdump --header pppd_dump.elf
pppd_dump.elf: file format elf32-littlenios2
Sections:
Idx Name Size VMA LMA File off Algn
0 .text 00023bf0 00000000 00000000 00000034 2**2
CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE
1 .data 000071c8 00023bf0 00023bf0 00023c24 2**2
CONTENTS, ALLOC, LOAD, RELOC, DATA, SMALL_DATA
2 .bss 0001bf54 0002adb8 0002adb8 0002adec 2**2
ALLOC
3 .comment 00000630 00000000 00000000 0002adec 2**0
CONTENTS, READONLY
4 .debug_aranges 00000460 00000000 00000000 0002b41c 2**0
CONTENTS, RELOC, READONLY, DEBUGGING
5 .debug_pubnames 000014bb 00000000 00000000 0002b87c 2**0
6 .debug_info 00012a78 00000000 00000000 0002cd37 2**0
7 .debug_abbrev 00003af3 00000000 00000000 0003f7af 2**0
CONTENTS, READONLY, DEBUGGING
8 .debug_line 00013bc5 00000000 00000000 000432a2 2**0
9 .debug_frame 00002150 00000000 00000000 00056e68 2**2
10 .debug_str 00009385 00000000 00000000 00058fb8 2**0
11 .debug_ranges 00000998 00009385 00009385 0006233d 2**0
[root@localhost pppd]# arm-elf-objdump --header pppd.gdb
pppd.gdb: file format elf32-littlearm
Sections:
0 .text 00024c20 00000000 00000000 00008000 2**4
CONTENTS, ALLOC, LOAD, READONLY, CODE
1 .data 00006bc0 00024c20 00024c20 0002cc20 2**4
CONTENTS, ALLOC, LOAD, DATA
2 .bss 0000a1c0 0002b7e0 0002b7e0 000337e0 2**4
ALLOC
3 .debug_abbrev 00014bc3 00000000 00000000 000337e0 2**0
4 .debug_info 002985c5 00000000 00000000 000483a3 2**0
5 .debug_line 0005f85c 00000000 00000000 002e0968 2**0
6 .debug_pubnames 0000373a 00000000 00000000 003401c4 2**0
7 .debug_aranges 00001c80 00000000 00000000 003438fe 2**0
Thank you for all response!
    --- Quote Start ---
    originally posted by smalllight@Apr 10 2006, 03:26 PM
    hi,hippo!
    i build the boa in the arm platform,the message boa process is as follow:# cat status
    state: s (sleeping)
    tgid: 60
    pid: 60
    ppid: 56
    tracerpid: 0
    uid: 0 0 0 0
    gid: 0 0 0 0
    fdsize: 32
    groups:
    mem: 157792 bytes
    slack: 2876 bytes
    shared: 0 bytes
    sigpnd: 0000000000000000
    sigblk: 0000000000000000
    sigign: 0000000000001a00
    sigcgt: 0000000000016443
    capinh: 0000000000000000
    capprm: 00000000fffffeff
    capeff: 00000000fffffeff
    can you show the boa process status in your nios platform?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14187)
    --- quote end ---
    --- Quote End ---
    Sorry for the delay, I was busy on a kernel issue.
    Here is boa status on nios2
    # cat status
    State: S (sleeping)
    SleepAVG: 87%
    Tgid: 28
    Pid: 28
    PPid: 26
    TracerPid: 0
    Uid: 0 0 0 0
    Gid: 0 0 0 0
    FDSize: 32
    Groups:
    Mem: 286112 bytes
    Slack: 52682 bytes
    Shared: 0 bytes
    Threads: 1
    SigPnd: 0000000000000000
    ShdPnd: 0000000000000000
    SigBlk: 0000000000000000
    SigIgn: 0000000000001004
    SigCgt: 0000000000014643
    CapInh: 0000000000000000
    CapPrm: 00000000fffffeff
    CapEff: 00000000fffffeff#
    Dear Hippo,
    We build our boa application in our platform! we list the status.
    and could you please send us you code of boa ,then we can compare them,
    our boa version 0.94# cat /proc/108/status
    State: S (sleeping)
    SleepAVG: 89%
    Tgid: 108
    Pid: 108
    PPid: 89
    TracerPid: 0
    Uid: 0 0 0 0
    Gid: 0 0 0 0
    FDSize: 32
    Groups:
    Mem: 273568 bytes
    Slack: 71494 bytes
    Shared: 0 bytes
    Threads: 1
    SigCgt: 0000000000016643
    Fei WU
    e-mail: [email protected]
    --- Quote Start ---
    originally posted by feiwu@Apr 13 2006, 10:51 AM
    dear hippo,
    we build our boa application in our platform! we list the status.
    state: s (sleeping)
    sleepavg: 89%
    tgid: 108
    pid: 108
    ppid: 89
    tracerpid: 0
    uid: 0 0 0 0
    gid: 0 0 0 0
    fdsize: 32
    groups:
    mem: 273568 bytes
    slack: 71494 bytes
    shared: 0 bytes
    threads: 1
    shdpnd: 0000000000000000
    sigign: 0000000000001004
    sigcgt: 0000000000016643
    best regards,
    fei wu
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14297)
    --- quote end ---
    --- Quote End ---
    it was in ~/apps/boa, which was ported by Microtronix.
    Dear hippo!
    I compare the status of boa process in your platform and my arm platform.
    the result as follow:
    my arm platform:
    compare
    Mem: 157792 bytes
    Slack: 2876 bytes
    Shared: 0 bytes
    your nios platform:
    Mem: 286112 bytes
    Slack: 52682 bytes
    Shared: 0 bytes
    you can see nios plat forum user more memory than arm.
    In my arm platform, the linux sourse verision is 2.4
    if the application will consume more memory in the 2.6 kernel?
    can you help me?
    --- Quote Start ---
    originally posted by smalllight@Apr 17 2006, 11:05 AM
    dear hippo!
    i compare the status of boa process in your platform and my arm platform.
    my arm platform:
    compare
    mem: 157792 bytes
    slack: 2876 bytes
    shared: 0 bytes
    your nios platform:
    mem: 286112 bytes
    slack: 52682 bytes
    shared: 0 bytes
    in my arm platform, the linux sourse verision is 2.4
    can you help me?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14414)
    --- quote end ---
    --- Quote End ---
    I would expect Nios2&#39;s code efficency will not be as good as ARM&#39;s. Because Nios2 has fewer instruction set.
    To reduce memory usage, there are some approaches.
    1. rebuild the lib and code with "-Os" flag.
    2. in Linux 2.6.12 or later, there is a CONFIG_BASE_SMALL, which will use smaller table size for kernel data.
    3. hack the kernel or apps to reduce memory usage and slack.
