20 years agohelp me,save my memory
hi! my application use more memory in the nios than arm platform I use the objdump print as follow: [root@localhost pppd]# nios2-elf-objdump --header pppd_dump.elf pppd_dump.elf: file...
20 years ago --- Quote Start --- originally posted by smalllight@Apr 10 2006, 03:26 PM hi,hippo!
i build the boa in the arm platform,the message boa process is as follow:# cat status
state: s (sleeping)
tgid: 60
pid: 60
ppid: 56
tracerpid: 0
uid: 0 0 0 0
gid: 0 0 0 0
fdsize: 32
groups:
mem: 157792 bytes
slack: 2876 bytes
shared: 0 bytes
sigpnd: 0000000000000000
sigblk: 0000000000000000
sigign: 0000000000001a00
sigcgt: 0000000000016443
capinh: 0000000000000000
capprm: 00000000fffffeff
capeff: 00000000fffffeff
can you show the boa process status in your nios platform?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14187)
--- quote end ---
--- Quote End --- Sorry for the delay, I was busy on a kernel issue. Here is boa status on nios2 # cat status Name: boa State: S (sleeping) SleepAVG: 87% Tgid: 28 Pid: 28 PPid: 26 TracerPid: 0 Uid: 0 0 0 0 Gid: 0 0 0 0 FDSize: 32 Groups: Mem: 286112 bytes Slack: 52682 bytes Shared: 0 bytes Threads: 1 SigPnd: 0000000000000000 ShdPnd: 0000000000000000 SigBlk: 0000000000000000 SigIgn: 0000000000001004 SigCgt: 0000000000014643 CapInh: 0000000000000000 CapPrm: 00000000fffffeff CapEff: 00000000fffffeff#
