20 years agohelp me,save my memory
hi! my application use more memory in the nios than arm platform I use the objdump print as follow: [root@localhost pppd]# nios2-elf-objdump --header pppd_dump.elf pppd_dump.elf: file...
20 years agoDear hippo!
I compare the status of boa process in your platform and my arm platform. the result as follow: my arm platform: compare Mem: 157792 bytes Slack: 2876 bytes Shared: 0 bytes your nios platform: Mem: 286112 bytes Slack: 52682 bytes Shared: 0 bytes you can see nios plat forum user more memory than arm. In my arm platform, the linux sourse verision is 2.4 if the application will consume more memory in the 2.6 kernel? can you help me?
