15 years ago
help me please!!! alt_flash_open_dev return error
I use sst flash 39vf6401 on my borad.When I need to progamme the flash, I should add a CFI table .Then I can download the programme to the flash successfully.
But I can not open the flash while alt_flash_open_dev(). The return value of alt_flash_open_dev() is always wrong.
If any one know something about it, please help me ,Thank you !
    But as I understand you can flash the cfi flash using the Flash programmer, don't you?
    What specific problem do you have so you need to write theCFI table to your flash?
    --- Quote Start ---
    --- Quote End ---
    thank you!
    if I don't add cfi table,I will fail to program the flash.
    my problem is that I can not open the flash in nios.the return value of alt_flash_open_dev is always '0'
    --- Quote Start ---
    thank you!
    --- Quote End ---
    delphicgp, do you use "reduced device drivers" option in the BSP?
    try different and slow serial frequencies. I had the same problem and when I reduce the freq it start working.
    Call the alt_flash_open_dev function only when operating in single-threaded mode.
