15 years ago --- Quote Start --- But as I understand you can flash the cfi flash using the Flash programmer, don't you? What specific problem do you have so you need to write theCFI table to your flash? --- Quote End --- thank you! if I don't add cfi table,I will fail to program the flash. my problem is that I can not open the flash in nios.the return value of alt_flash_open_dev is always '0'
