Altera_ForumHonored Contributor15 years agohelp me please!!! alt_flash_open_dev return error I use sst flash 39vf6401 on my borad.When I need to progamme the flash, I should add a CFI table .Then I can download the programme to the flash successfully. But I can not open the flash whil...Show More
Altera_ForumHonored Contributor14 years agoCall the alt_flash_open_dev function only when operating in single-threaded mode.
Recent DiscussionsUSING SIGNAL TAP TO MONOTOR AVALON_BUS WITH NIOS DESIGNDK-DEV-AGI027-RA: JTAG chain broken after Nios V Hello, FPGA recovery failsNIOS does not start after SW download (timing issue?)Nios V licensereCAPTCHA Verification failed
