15 years ago --- Quote Start --- thank you! if I don't add cfi table,I will fail to program the flash. my problem is that I can not open the flash in nios.the return value of alt_flash_open_dev is always '0' --- Quote End --- delphicgp, do you use "reduced device drivers" option in the BSP?
