TonyH
4 years agoHAL API for the Generic Serial Flash Interface FPGA IP, 'altera_safeclib'
In the user guide for the Generic Serial Flash Interface (GSFI) it says "altera_safeclib" must be enabled in the BSP editor to use the HAL API for this device.
With a Quartus 21.1 install and the a...
KennyT_altera
4 years agoThis case had been closed on 03-17-2022 per mention in the message above. Can you opened a new thread for the support?
Usually, if the case idle too long, we would close the case.
meenalkb
4 years agoHi Kenny
I've got a new one here now. My problem is identical to the OP's.
Waiting for your reply.
- anonimcs2 years ago
Contributor
Hi @KennyTan_Altera ,
I also have the same issue with the OP @TonyH and @meenalkb , which I also mentioned in a separate forum entry . Waiting for your (or one of the employee's like @EBERLAZARE_I_Intel ) reply.
