9 years ago
FPGA to SDRAM AXI Transfer
I'm doing a project with Arria V SoC using the HPS and FPGA parts. In the FPGA, I have a custom IP with AXI Master interface on it.
This IP should read and write from/to the SDRAM directly. However, I can only do read operation! The write operation does not work.
The data in SDRAM is provided by HPS (running Linux). For now, I'm using /dev/mem to write the data to the SDRAM.
Using the same method, I found that the data is never written from FPGA.
1. Can you help me with this issue? Anyone has already done a work using AXI and SDRAM?
2. In Qsys, my AXI master should be connected to the SDRAM, right? Did I do some mistake? I connect it to f2h_sdram0_data, not f2h_axi_slave on hps_0.
3. Is there any configuration that I need to do in the AXI to perform read and write?
Thank you so much for your help.
    Never mind. Found it.
    --- Quote Start ---
    --- Quote End ---
    --- Quote Start ---
    --- Quote End ---
    If you post your solution it can help others in the future, who will most likely be very grateful!
  • MSene1's avatar
    MSene1
    I am reopenning this issue because I am having the same problem.
    Only my read interface is working but the write doesn't work.
    If someone knows the solution I would be thankful.
    thank you for your help
