9 years agoFPGA to SDRAM AXI Transfer
Hello, I'm doing a project with Arria V SoC using the HPS and FPGA parts. In the FPGA, I have a custom IP with AXI Master interface on it. This IP should read and write from/to the SDRAM dire...
9 years agoNever mind. Found it.
--- Quote Start --- Hello, I'm doing a project with Arria V SoC using the HPS and FPGA parts. In the FPGA, I have a custom IP with AXI Master interface on it. This IP should read and write from/to the SDRAM directly. However, I can only do read operation! The write operation does not work. The data in SDRAM is provided by HPS (running Linux). For now, I'm using /dev/mem to write the data to the SDRAM. Using the same method, I found that the data is never written from FPGA. 1. Can you help me with this issue? Anyone has already done a work using AXI and SDRAM? 2. In Qsys, my AXI master should be connected to the SDRAM, right? Did I do some mistake? I connect it to f2h_sdram0_data, not f2h_axi_slave on hps_0. 3. Is there any configuration that I need to do in the AXI to perform read and write? Thank you so much for your help. --- Quote End ---
