9 years agoFPGA to SDRAM AXI Transfer
Hello, I'm doing a project with Arria V SoC using the HPS and FPGA parts. In the FPGA, I have a custom IP with AXI Master interface on it. This IP should read and write from/to the SDRAM dire...
MSene1
7 years agoHi,
I am reopenning this issue because I am having the same problem.
Only my read interface is working but the write doesn't work.
If someone knows the solution I would be thankful.
thank you for your help
