19 years agoFlash Programmer!
Hi,hippo
I following WiKiHome's "Flash Programmer Guide" try out flash. I have to test the new kerenl image with nios2-download. Don't run nios2-terminal, use Hyper-terminal on Windows. Make sure it runs correctly over the RS-232C COM port. It'sOK! But when i programmer image on EPCS flash,than power up my Hyper-terminal message has no any message. What's problem? I make sure "sof file" it already program on EPCS flash. I have a doubt, when i want to program "sof on EPCS flash" and "image on CFI flash" how to select "reset address"? Can you give me some hint? PS: my dev board is DE2. Thank you very much! NiosQ6 Replies
Hi NIOSQ:
You have to select your reset addres in SOPC Builder when building the NIOS system. There you must set it to point to CFI flash. I hope this helps, Luis - Altera_Forum
--- Quote Start --- originally posted by luisalba@Mar 27 2007, 02:14 AM hi niosq:you have to select your reset addres in sopc builder when building the nios system. there you must set it to point to cfi flash.
i hope this helps,
luis
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22535)
--- quote end ---
--- Quote End --- Hi,luisalba Thank you for your reply. I look "nios2_systems.h" found my EPCS flash can uses space only 800KB,so I thank the size is to small , my build "sof file is 310KB" and "image file is 1300KB". Anyone know howe to increase EPCS flash size? NiosQ
I have just updated the wiki page with more details. Please check.
--- Quote Start --- originally posted by hippo@Mar 27 2007, 11:18 PM i have just updated the wiki page with more details. please check.<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22574)
--- quote end ---
--- Quote End --- Hi,hippo Thank you very much! Can you give me DE2_NET v1.4a project? My project is DE2_NET v1.1 Please! NiosQ
You can use v1.5, it should be the same.
ftp://ftp.altera.com/up/pub/de2/de2_system_v1.5.zip (ftp://ftp.altera.com/up/pub/de2/de2_system_v1.5.zip) - Altera_Forum
--- Quote Start --- originally posted by hippo@Mar 28 2007, 02:17 AM you can use v1.5, it should be the same.ftp://ftp.altera.com/up/pub/de2/de2_system_v1.5.zip (ftp://ftp.altera.com/up/pub/de2/de2_system_v1.5.zip)
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22579)
--- quote end ---
--- Quote End --- Hi,hippo It's work!!! Thank you very much. I try out it many day. I deeply appreciated your helped, because you it just can work! Thx! NiosQ
