19 years agoFlash Programmer!
Hi,hippo I following WiKiHome's "Flash Programmer Guide" try out flash. I have to test the new kerenl image with nios2-download. Don't run nios2-terminal, use Hyper-terminal on Win...
19 years agoHi NIOSQ:
You have to select your reset addres in SOPC Builder when building the NIOS system. There you must set it to point to CFI flash. I hope this helps, Luis
