19 years agoFlash Programmer!
Hi,hippo I following WiKiHome's "Flash Programmer Guide" try out flash. I have to test the new kerenl image with nios2-download. Don't run nios2-terminal, use Hyper-terminal on Win...
19 years ago --- Quote Start --- originally posted by luisalba@Mar 27 2007, 02:14 AM hi niosq:
you have to select your reset addres in sopc builder when building the nios system. there you must set it to point to cfi flash.
i hope this helps,
luis
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22535)
--- quote end ---
--- Quote End --- Hi,luisalba Thank you for your reply. I look "nios2_systems.h" found my EPCS flash can uses space only 800KB,so I thank the size is to small , my build "sof file is 310KB" and "image file is 1300KB". Anyone know howe to increase EPCS flash size? NiosQ
