Fft In Sopc
Guyz please help , if u have an idea.
Uptil now i made a 64 point FFT using megacore and added it to the sopc as a new component but there are a lot of signals and so it gives me an error when i generate it. I believe i need a wrapper code for my FFT. CAN SUM1 HELP ME OUT WITH IT. THANKS webster_dev at the rate yahoo.com39 Replies
i used ur wrapper and created my system using sopc.but when i see the nios_sytem.vhd file there are no fft inclusion in that file.But my project was succesfully compiled.
the steps i followed was that 1. i went to megacore wizard generated my fft for streaming architecture(which architecture is better for speech recognition) 2. i went to sopc created my fft component adding fft.vhd file (i think i have problem here in majd included files i did not find picture attached for creating fft component and what files need to be included and its interfaces) 3.i added the fft_wapper.vhd and created a new component fft_wrapper as in majd tutorial. 4. i added all necessary components(sgdma,rams) Plz help me how to create fft component including your system image my project is on speech recognition and i have my presentation scheduled in DEC 5 2010 so i am getting hopeless plz help me. - Altera_Forum
--- Quote Start --- i used ur wrapper and created my system using sopc.but when i see the nios_sytem.vhd file there are no fft inclusion in that file.But my project was succesfully compiled. the steps i followed was that 1. i went to megacore wizard generated my fft for streaming architecture(which architecture is better for speech recognition) 2. i went to sopc created my fft component adding fft.vhd file (i think i have problem here in majd included files i did not find picture attached for creating fft component and what files need to be included and its interfaces) 3.i added the fft_wapper.vhd and created a new component fft_wrapper as in majd tutorial. 4. i added all necessary components(sgdma,rams) Plz help me how to create fft component including your system image my project is on speech recognition and i have my presentation scheduled in DEC 5 2010 so i am getting hopeless plz help me. --- Quote End --- I believe that step 2 may be where the problem is. The beautiful thing abou the FFT wrapper file is that you do not need to add the actual FFT files directly in the SOPC builder. Try these steps: 1. Generate your FFT component, just as you have before. Make note of the name of the component (for example fft_64_.vhd). It should be the "top" level for the the FFT that was generated by the wizard. 2. Open up the fft_wrapper.vhd file and replace "fft_1024", with the name of the FFT file created for you through the wizard (for example, the entity name for the fft_64.vhd component you just created). 3. You will probably need to edit the fft_wrapper further, depending on your FFT implementation:- If you are using floating point (add signals for the exponent), since my implementation was fixed point. (Hint - use fixed point :))
- If the bit width for the real and imaginary outputs from the FFT is greater than 32 bits (if the width is greater than 64 bits when combined into a single vector). (Hint - keep the bit width of each component below the 32 bits and you should be ok).
- If the input is greater that 32 bits for your FFT (16 bits for imaginary and 16 for real).
- If you want to control the direction of the FFT (the inverse input), you will need some additional logic, or perhaps there is another way. But, I just hardcoded the wrapper to keep the FFT in a single direction.
i am not getting how to give signal to fft . i have ADC output at sdram and have to give this signal as input to fft . what about other signals are they defined in fft wrapper. plz help me add the signal and how to check whether my fft is working or not. i have to get fft output and compare it for speech recognition.plz reply soon
in given code by majd i donot get why sig[i] is used - Altera_Forum
Hi All,
Does anyone know how to perform FFT using some FFT size and combine after completed all the chunk of data rather than using on big FFT size in FPGA point of view? For example, compute 32k FFT using 8192 FFT size with repeating 4x using the same 8k FFT? The reason to do this is to reutilized the FFT logic inside the FPGa in order to save logic consumption. - Altera_Forum
xfpga,
There are several ways to accomplish this with algorithms. The easiest and perhaps the most inefficient way of doing it is to: 1.) Decimate the data 2.) Perform the block FFT on each set of decimated data 3.) Recombine each of the FFT outputs together. In order to do this you need to multiply each contribution by a coefficient that effectively "weights" each contribution. 4.) Store the result. That is the basic gist of it. I will provide you with a more formal description to follow... - Altera_Forum
The example that you gave was to use a 8k FFT to compute a 32k FFT. Let N be your desired FFT size, in this case 32768. Also let M be your block FFT size, which in this case will be 8192.
Lets suppose that your 32768 data points are stored in a contiguous piece of memory. Lets refer to this set of data as x(n) where n ranges from 0 to 32767. Next, we perform the M-point FFTs on the decimated representations of x(n). Since M = 8192 and N = 32768, we know that we will need to perform 4 block FFT operation (note that the M does not need to be an integer multiple of M...). Let's call this number L, where L = ceil[N/M]. Follow the following steps:- Perform an M-point FFT on the x(n) samples where n = 0, 4, 8, ..., ( ((N-1) -3). We'll call those FFT results x0(k).
- Store four copies of x0(k) in an array/memory.
- Next we compute an M-point FFT on the x(n) samples where n = 1, 5, 9, ..., ((N-1) -2). We call those FFT results x1(k).
- Store four copies of x1(k) in an array/memory.
- Next we compute an M-point FFT on the x(n) samples where n = 2, 6, 10, ..., ((N-1) -1). We call those FFT results x2(k).
- Store four copies of x2(k) in an array/memory.
- Next we compute an M-point FFT on the x(n) samples where n = 3, 7, 11, ..., ((N-1) - 0). We call those FFT results x3(k).
- Store four copies of x3(k) in an array/memory.
Thanks a lot for your advices. When implementing the FFT which method will be more efficient, in NIOS or hardware(logic gates)? The reason I ask is because from the method you mentioned it involve arrangement of data and multiplication of coefficient matrix, L. Understand that the FFT IP core from Altera consumed quite a lot of logic. Do you have any references to implement this from scratch? Thanks. - Altera_Forum
--- Quote Start --- Hi, Thanks a lot for your advices. When implementing the FFT which method will be more efficient, in NIOS or hardware(logic gates)? The reason I ask is because from the method you mentioned it involve arrangement of data and multiplication of coefficient matrix, L. Understand that the FFT IP core from Altera consumed quite a lot of logic. Do you have any references to implement this from scratch? Thanks. --- Quote End --- I suppose that you could implement a full-custom FFT core. But, chances are that it will not be as effecient as the cores that Altera has already provided in the mega core. The method above can be implemented in software (utilizing the FFT megacore NIOS) without too much headache. While I do not have a reference design for you, I can give you a rough step-by-step to implement it in software:- Generate the largest FFT based upon the resources of your FPGA/development board.
- Next, you will need to create an SOPC system that contains a NIOS core, FFT wrapper (you can refer to the wrapper in a previous thread in this post), and also some memory. I recommend you use DDR if you have it available...but i suppose internal RAM could work. The wrapper is basically a shell that encapsulated the FFT component.
- Once your system is up and running, you can then write a program in C for NIOS that does all of the matrix operations for you. This is where this method loses efficiency - since NIOS is doing all of the math, it will be sllllooooooowww! The tradeoff however, is that you can accomplish larger FFTs that what is provided by Altera with relative ease.
why the program stuck in this line?
while (IORD(SGDMA_ST_TO_MM_FFT_BASE,0)!=14) {}; when i check the return value of IORD(SGDMA_ST_TO_MM_FFT_BASE,0) is always 8. could somebody give me a solution? Should we add a process in the wrapper? thanks... Here is the fft code wrapper as mentioned earlier in the thread. module fft_avalon_wraper ( clk, reset_n, mm_writedate, mm_write, sink_valid, sink_sop, sink_eop, sink_empty, sink_real, // sink_imag, sink_error, source_ready, sink_ready, source_error, source_sop, source_eop, source_valid, source_data, source_empty // ,source_exp ); input clk; input reset_n; input [7 : 0] mm_writedate; input mm_write; input sink_valid; input sink_sop; input sink_eop; input [2 : 0] sink_empty; input [31 : 0] sink_real; //input [31 : 0] sink_imag; input [1 : 0] sink_error; input source_ready; output sink_ready; output [1 : 0] source_error; output source_sop; output source_eop; output source_valid; output [31 : 0] source_data; output [2 : 0] source_empty; //output [5 : 0] source_exp; reg inverse=0; reg [15 : 0]sink_imag=0; wire [5 : 0] source_exp; reg [10 :0] fftpts_in; FFT fft ( .clk(clk), .reset_n(reset_n), .inverse(inverse), .sink_valid(sink_valid), .sink_sop(sink_sop), .sink_eop(sink_eop), .sink_real(sink_real[15 : 0]), .sink_imag(sink_imag), .sink_error(sink_error), .source_ready(source_ready), .sink_ready(sink_ready), .source_error(source_error), .source_sop(source_sop), .source_eop(source_eop), .source_valid(source_valid), .source_exp(source_exp), .source_real(source_data[15 : 0]), .source_imag(source_data[31 : 16])); endmodule
