16 years agoFft In Sopc
Guyz please help , if u have an idea. Uptil now i made a 64 point FFT using megacore and added it to the sopc as a new component but there are a lot of signals and so it gives me an error when ...
15 years agoxfpga,
There are several ways to accomplish this with algorithms. The easiest and perhaps the most inefficient way of doing it is to: 1.) Decimate the data 2.) Perform the block FFT on each set of decimated data 3.) Recombine each of the FFT outputs together. In order to do this you need to multiply each contribution by a coefficient that effectively "weights" each contribution. 4.) Store the result. That is the basic gist of it. I will provide you with a more formal description to follow...
