16 years agoFft In Sopc
Guyz please help , if u have an idea. Uptil now i made a 64 point FFT using megacore and added it to the sopc as a new component but there are a lot of signals and so it gives me an error when ...
14 years agowhy the program stuck in this line?
while (IORD(SGDMA_ST_TO_MM_FFT_BASE,0)!=14) {}; when i check the return value of IORD(SGDMA_ST_TO_MM_FFT_BASE,0) is always 8. could somebody give me a solution? Should we add a process in the wrapper? thanks... Here is the fft code wrapper as mentioned earlier in the thread. module fft_avalon_wraper ( clk, reset_n, mm_writedate, mm_write, sink_valid, sink_sop, sink_eop, sink_empty, sink_real, // sink_imag, sink_error, source_ready, sink_ready, source_error, source_sop, source_eop, source_valid, source_data, source_empty // ,source_exp ); input clk; input reset_n; input [7 : 0] mm_writedate; input mm_write; input sink_valid; input sink_sop; input sink_eop; input [2 : 0] sink_empty; input [31 : 0] sink_real; //input [31 : 0] sink_imag; input [1 : 0] sink_error; input source_ready; output sink_ready; output [1 : 0] source_error; output source_sop; output source_eop; output source_valid; output [31 : 0] source_data; output [2 : 0] source_empty; //output [5 : 0] source_exp; reg inverse=0; reg [15 : 0]sink_imag=0; wire [5 : 0] source_exp; reg [10 :0] fftpts_in; FFT fft ( .clk(clk), .reset_n(reset_n), .inverse(inverse), .sink_valid(sink_valid), .sink_sop(sink_sop), .sink_eop(sink_eop), .sink_real(sink_real[15 : 0]), .sink_imag(sink_imag), .sink_error(sink_error), .source_ready(source_ready), .sink_ready(sink_ready), .source_error(source_error), .source_sop(source_sop), .source_eop(source_eop), .source_valid(source_valid), .source_exp(source_exp), .source_real(source_data[15 : 0]), .source_imag(source_data[31 : 16])); endmodule
