22 years agoExternal SRAM interface
From the Nios II DK, the two IDT SRAM's (256kB x 16) are set up in 32-bit words. Since our design will only use one SRAM of smaller size (128kB x 16), would I have to import, say a VHDL source, to implement it within SOPC? How can the control signals get tied in with the Avalon bus without having the signals generated as external ports?
Use Interface to userlogic:
Bus Interface Type: Avalon Memory Slave select add generic list of ports and edit it to the following. PORT NAME | Width | Direction | Shared | Type address | 17 | input | yes | address write_n | 1 | input | yes | write_n read_n | 1 | input | yes | read_n writedata | 16 | inout | yes | data chipselect_n | 1 | input | --- | chipselect_n be_n | 2 | input | yes | byteenable_n timing: I use 2 wait and 1 hold cycle (can be optimized) - Altera_Forum
Thanks for the instructions. One more question, since the SRAM has lower-byte and upper-byte controls, would both be identified as byteenable_n?
you should get the signals
nnnn_byteenablen[1..0] where nnnn is the name of your Avalon Tristate Bridge connect nnnn_byteenablen[0] to \BLE of SRAM connect nnnn_byteenablen[1] to \BHE of SRAM - Altera_Forum
Thanks for all your help Fischer. I'm starting to getting the hang of it. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
