Ethernet autonegotiation
I am just wondering what kind of procedures are running during the link establishment in 100Base-T ethernet in case auto negotiation is disabled (i.e. forced mode) at both ends of the ethernet connection (i.e. switch and NIC)?
Thanks,15 Replies
None :-)
However directly forcing the mode is generally a bad idea - it tends to end up with mismatches, some of which are hard to diagnose. If you want to force (say) 100M FDX the best thing is to set the the PHYs auto negotiate advertise register (ANAR) with the single bit for the the desired mode. Then the negotiation will still happen, but the outcome is guaranteed [1]. [1] Unless you connect to an old 10M hub (which doesn't do any detection) or an old dual speed 10/100M hub that uses auto-detect not auto-negotiate. Anything that will do full duplex supports auto-negotiation. - Altera_Forum
Thanks for the reply. I agree that using auto-negotiation is a good practice but I am just wondering whether there is another state diagram similar to auto-negotiation in case both end nodes disable auto-negotiation. Actually I have a very simple configuration with 2 hosts with a single switch. When I perform ethtool eth1, then I saw two lines related to auto-negotiation. First is "advertised auto-negotiation : Yes" and second "Auto-negotiation : off". So in this configuration I think although auto-nego is disabled, the card still advertises its capabilities to the other end.
Some history might help:
The original 10M HDX for UTP included 'link test pulses', a single pulse was sent at a fixed rate, reception of the pulses would typically light a little led, the polarity of the pulses could be uses to detect mis wired cables. Later cards would also auto-detect cross over (by detecting pulses on the tx pair). 100M HDX used a short burst of pulses to indicate support for 100M (and 10M), a 10M phy would treat them normally, a 100M phy would detect the burst and then auto-detect that it could use at 100M. Old dual speed hubs are two separate hubs (one for each speed) connected via a bridge. With the advent of FDX the burst of link test pulses was modified so that some of the pulses would be missing. This enabled specific register values (not only the ANAR) to be passed to the remote PHY. A 100M HDX hub would still treat it as a valid burst and do 100M. The standard MII phy interface defined 16 registers (it might have been extended). The first 8 are vendor independant and contain the ANAR and the ANRR? (received ANAR value), what they don't contain is the actual operating mode - which can be difficult to determine. There are a lot of devices that don't like being connected to 10/100 hubs. For 10M and 100M the link test pulses are sent at regular intervals. For Ge and higher things are more complicated, once the initial negotiation has happened the data pairs get connected to a powerful DSP. I suspect that regular link test pulses are no longer sent. - Altera_Forum
Thanks for the reply. When you say 'link test pulses', do you mean FLPs? or are they different pulses than FLPs in 100M case for example. When I read 802.3-2008, it talks about FLPs for 100M case that auto-nego process sends and receives many of them.
Probably :-)
Then, when we disable auto-negotiation at both sides, are they still transmitted?
FLPs are not transmitted if aneg is disabled, just idle. If a device that supports aneg sees idle from a link partner (instead of FLPs), then it can link with it via a "parallel detection" function. The device will assume the link is half duplex, since it doesn't know if the link partner is a half or full duplex device. It's typically a bad situation, since you can get a duplex mismatch. See Clause 28 of the IEEE 802.3 standard for a reference (28.2.3.1 in particular for a description of Parallel Detection).
BTW, in 1000Base-T, FLPs are still used, but they use next pages to transmit more information related to 1GE. There's a master/slave resolution and equalizer training that happens afterwards before the link actually comes up.
But, I think "parallel detection" is only used when one end node supports aneg. What I am wondering what happens when both end nodes disable aneg. In this case, do both nodes send idle messages? If yes, how one node react when it receives an idle message from the link partner?
Thanks, - Altera_Forum
I'm pretty sure that if autonegotiation is disabled some test pulses are still sent.
If you connect to a 10M hub, the 'link up' light will come on, whether a 10/100 hub selects 100M may depend on the phy and the actual selected mode. You can probably probe the wire with a 'scope....
