13 years agoEthernet autonegotiation
I am just wondering what kind of procedures are running during the link establishment in 100Base-T ethernet in case auto negotiation is disabled (i.e. forced mode) at both ends of the ethernet con...
13 years agoI'm pretty sure that if autonegotiation is disabled some test pulses are still sent.
If you connect to a 10M hub, the 'link up' light will come on, whether a 10/100 hub selects 100M may depend on the phy and the actual selected mode. You can probably probe the wire with a 'scope....
