16 years ago
Download image ok, but boot fail
Hi Guys,
I need help... maybe someone have passed for this trouble.
I try to run Linux on Nios II, obviously. My project is based on DE2_NET.
Now I used a CYCLONE II EP2C8F256C8 in a custom board.
First, I build the project for uCLinux and ran with sucess.
After that, I add the TCMs in the SOPC and uClinux ran with success.
So, after the system was validated, I went to LINUX with MMU.
After some days, I can to program/download the image in a Flash with sucess.
But the Linux don't boot.
The stdout is a jtag_uart.
When I run the “nios2-terminal”, nothing happen.
Don't show error or some information... the terminal was blank, like this:
[NiosII EDS]$ nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Well, the Address Map is this:
cpu.jtag_debug_module 0x08000000 - 0x080007ff
timer_0 0x08400000 - 0x0840001f
sysid 0x08004d40 - 0x08004d47
jtag_uart_0 0x08004d50 - 0x08004d57
timer1 0x08004d00 - 0x08004d1f
sdram_0 0x02000000 - 0x02ffffff
epcs_controller 0x00100000 - 0x001007ff
tri_state_bridge_0
ext_flash 0x00000000 - 0x000fffff
onchip_memory2_0.s1 0x08000800 - 0x08000bff
onchip_memory2_0.s2 0x08400400 - 0x084007ff
the sdram have 8mbyte (pn: is42s16800d).
the flash memory have 8mbyte (pn: mp25p64).
the pll on the sopc builder is 100mhz for all peripherals.
This is my script for download/program:
nios2-configure-sof mylinux_top.sof
sof2flash --verbose --epcs --input=mylinux_top.sof --output=mylinux.flash
nios2-flash-programmer --mmu --epcs --base=0x00100000 mylinux.flash
elf2flash --mmu --epcs --after=mylinux.flash --input=zimage.initramfs.gz --output=epcs_controller.flash --boot=$sopc_kit_nios2/components/altera_nios2/boot_loader_epcs.srec
nios2-flash-programmer --mmu --epcs --base=0x00100000 epcs_controller.flash
The result after run the “script” is:
NiosII EDS]$ ./script
Searching for SOF file:
in .
myLinux_top.sof
Info: *******************************************************************
Info: Running Quartus II Programmer
Info: Command: quartus_pgm --no_banner --mode=jtag -o p; myLinux _top.sof
Info: Using programming cable "USB-Blaster [USB-0]"
Info: Started Programmer operation at Wed May 26 09:35:39 2010
Info: Configuring device index 1
Info: Device 1 contains JTAG ID code 0x020B20DD
Info: Configuration succeeded -- 1 device(s) configured
Info: Successfully performed operation(s)
Info: Ended Programmer operation at Wed May 26 09:35:40 2010
Info: Quartus II Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 55 megabytes
Info: Processing ended: Wed May 26 09:35:40 2010
Info: Elapsed time: 00:00:05
Info: Total CPU time (on all processors): 00:00:03
26/05/2010 09:35:41 - (FINE) sof2flash: Starting
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option= myLinux.opt myLinux _top.sof myLinux.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 69 megabytes
Info: Processing ended: Wed May 26 09:35:48 2010
Info: Elapsed time: 00:00:07
Info: Total CPU time (on all processors): 00:00:05
Info: Command: quartus_cpf --no_banner --convert myLinux.pof myLinux.rpd
Info: Peak virtual memory: 67 megabytes
Info: Processing ended: Wed May 26 09:35:54 2010
Info: Elapsed time: 00:00:06
26/05/2010 09:35:55 - (FINE) sof2flash: Done
--mmu option was set true, EPCS virtual address is base + offset of 0xC0000000
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Checksummed/read 60kB in 1.7s
Erased 192kB in 2.0s (96.0kB/s)
programmed 133kb +59kb in 5.1s (37.6kb/s)
Did not attempt to verify device contents
Leaving target processor paused
Checksummed/read 58kB in 1.5s
Erased 3712kB in 38.2s (97.1kB/s)
programmed 3655kb +57kb in 128.4s (28.9kb/s)
After power off/on custom board, I call the terminal:
Please, suggestions...
Thanks in advance.
Fernando Andrade
    Hi Hippo,
    Sorry for my delay.
    See the results:
    # linux.initramfs.gz
    [NiosII EDS]$ nios2-configure-sof myLinux_top.sof
    in .
    myLinux_top.sof
    Info: Command: quartus_pgm --no_banner --mode=jtag -o p;myLinux_top.sof
    Info: Started Programmer operation at Mon May 31 23:18:01 2010
    Info: Ended Programmer operation at Mon May 31 23:18:02 2010
    Info: Peak virtual memory: 89 megabytes
    Info: Processing ended: Mon May 31 23:18:02 2010
    Info: Elapsed time: 00:00:02
    Info: Total CPU time (on all processors): 00:00:00
    ~/Downloads
    [NiosII EDS]$ nios2-download -g linux.initramfs.gz
    Pausing target processor: OK
    Initializing CPU cache (if present)
    OK
    Downloaded 4845KB in 0.8s (6056.2KB/s)
    Verified OK
    Starting processor at address 0xC2000000
    assertion "m_state == STATE_DEBUG" failed: file "nios2debug.cpp", line 562
    2 [sig] nios2-gdb-server 4752 c:\altera\91\nios2eds\bin\nios2-gdb-server.exe: *** fatal error - called with threadlist_ix -1
    /cygdrive/c/altera/91/nios2eds/bin/nios2-download: line 595: 4752 Hangup nios2-gdb-server --go --tcpport none --write-pid ./nios2-download.pid ./linux.initramfs.gz.srec
    ~/Downloads
    [NiosII EDS]$
    # zImage.initramfs.gz
    in .
    myLinux_top.sof
    Info: Started Programmer operation at Mon May 31 23:20:59 2010
    Info: Ended Programmer operation at Mon May 31 23:21:00 2010
    Info: Processing ended: Mon May 31 23:21:00 2010
    ~/Downloads
    [NiosII EDS]$ nios2-download -g zImage.initramfs.gz
    OK
    Downloaded 3643KB in 0.8s (4553.7KB/s)
    Verified OK
    Starting processor at address 0xC2500000
    171 [sig] nios2-gdb-server 5988 c:\altera\91\nios2eds\bin\nios2-gdb-server.exe: *** fatal error - called with threadlist_ix -1
    /cygdrive/c/altera/91/nios2eds/bin/nios2-download: line 595: 5988 Hangup nios2-gdb-server --go --tcpport none --write-pid ./nios2-download.pid ./zImage.initramfs.gz.srec
    ~/Downloads
    [NiosII EDS]$
    I looked your address map again
    onchip_memory2_0.s2 0x08400400 - 0x084007ffs1 and s2 should have the same address.
    - Hippo
    Hi Hippo,
    Good tip...
    Now, I changed the onchip_memory2_0.S1 and onchip_memory2_0.S2 to same address (0x08000800).
    Well, I got two results because I ran with two USB-Blaster cable.
    One is a original ALTERA USB-Blaster cable (rev c) and other is a CUSTOM USB-Blaster cable (probably based on rev. A).
    Bellow I print the results for each case.
    Sorry for so much information.
    custom usb-blaster cable + linux.initramfs.gz
    [NiosII EDS]$ nios2-configure-sof embraer_top.sof
    in .
    embraer_top.sof
    Info: Command: quartus_pgm --no_banner --mode=jtag -o p;embraer_top.sof
    Info: Started Programmer operation at Tue Jun 01 20:47:24 2010
    Info: Ended Programmer operation at Tue Jun 01 20:47:25 2010
    Info: Processing ended: Tue Jun 01 20:47:25 2010
    ~/Downloads
    OK
    Downloaded 4845KB in 84.7s (57.2KB/s)
    Verified OK
    ~/Downloads
    nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios
    nios2-terminal: II systems. You may experience intermittent JTAG communication
    nios2-terminal: failures with this cable. Please use a USB Blaster revision B
    nios2-terminal: cable or another supported cable. Please refer to the file
    nios2-terminal: errata.txt included in the Nios II development kit documents
    nios2-terminal: directory for more information.
    Linux version 2.6.30-00494-g84a224b-dirty (tcb@vostromdv) (gcc veLinux version 2.6.30-00514-ge7e25ac-dirty (tcb@vostromdv) (gcc version 4.1.2)# 4 Mon May 31 23:02:17 BRT 2010
    console [early0] enabled
    Early printk initialized
    Linux/Nios II-MMU
    init_bootmem_node(?,0x24d3, 0x2000, 0x3000)
    free_bootmem(0x24d3000, 0xb2d000)
    reserve_bootmem(0x24d3000, 0x200)
    Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4064
    Kernel command line:
    NR_IRQS:32
    PID hash table entries: 64 (order: 6, 256 bytes)
    Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
    Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
    We have 12288 pages of RAM
    Memory available: 11288k/4937k RAM, 0k/0k ROM (1728k kernel code, 3209k data)
    Calibrating delay loop... 49.35 BogoMIPS (lpj=246784)
    Mount-cache hash table entries: 512
    net_namespace: 296 bytes
    NET: Registered protocol family 16
    init_BSP(): registering device resources
    bio: create slab <bio-0> at 0
    NET: Registered protocol family 2
    IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
    TCP established hash table entries: 512 (order: 0, 4096 bytes)
    TCP bind hash table entries: 512 (order: -1, 2048 bytes)
    TCP: Hash tables configured (established 512 bind 512)
    TCP reno registered
    msgmni has been set to 22
    io scheduler noop registered
    io scheduler anticipatory registered
    io scheduler deadline registered
    io scheduler cfq registered (default)
    ttyJ0 at MMIO 0x8004d50 (irq = 1) is a Altera JTAG UART
    console handover: boot [early0] -> real [ttyJ0]
    mice: PS/2 mouse device common for all mice
    TCP cubic registered
    NET: Registered protocol family 17
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    sh invoked oom-killer: gfp_mask=0xd0, order=1, oomkilladj=0
    Stack from c293ce2c:<0>
    <0> 000000d0<0> c2044da4<0> 00000000<0> c24c8e80<0> 000000d0<0> 00000001<0> c202beac<0> c2541c20<0>
    <0> 00000000<0> c2209170<0> c2541c20<0> c2209170<0> c20451ac<0> 00000000<0> c21e2518<0> 00000007<0>
    <0> 0baff100<0> 000000d0<0> 00000001<0> 000000d0<0> 00000001<0> c22155e4<0> 00000000<0> 00000000<0>
    <0> c20452a0<0> 00000000<0> 00000000<0> c2541c20<0> c2048560<0> 00000001<0> 00000048<0> 00000000<0>
    <0> 00000000<0> 00000000<0> 00000042<0> 00000000<0> 00000001<0> 00000010<0> 000200d0<0> 00000001<0>
    <0> 00000000<0> 00000000<0> c24c308c<0> c2541c20<0> 01200011<0> c254b680<0> 00000000<0> 2ac06048<0>
    Call Trace:<0>
    <0> [<c20486ac>]<0> [<c200e1e4>]<0> [<c201f808>]<0> [<c200f1c0>]<0>
    <0> [<c200afd0>]<0> [<c20023b4>]<0> [<c2000cf8>]<0> [<c2000888>]<0>
    Mem-Info:
    DMA per-cpu:
    CPU 0: hi: 0, btch: 1 usd: 0
    Active_anon:12 active_file:0 inactive_anon:32
    inactive_file:0 unevictable:1794 dirty:0 writeback:0 unstable:0
    free:657 slab:280 mapped:151 pagetables:8 bounce:0
    DMA free:2628kB min:4096kB low:5120kB high:6144kB active_anon:48kB inactive_anon:128kB active_file:0kB inactive_file:0kB unevictable:7176kB present:16256kB pages_scanned:0 all_unreclaimable? no
    lowmem_reserve[]: 0 0 0
    DMA: 3*4kB 3*8kB 2*16kB 0*32kB 0*64kB 0*128kB 0*256kB 1*512kB 0*1024kB 1*2048kB 0*4096kB = 2628kB
    1794 total pagecache pages
    4096 pages RAM
    1274 pages reserved
    226 pages shared
    1972 pages non-shared
    Out of memory: kill process 587 (sh) score 30 or a child
    Killed process 587 (sh)
    Kernel panic - not syncing: Out of memory and no killable processes...
    cont...
    altera usb-blaster + zimage.initramfs.gz
    in .
    embraer_top.sof
    Info: Started Programmer operation at Tue Jun 01 20:46:05 2010
    Info: Ended Programmer operation at Tue Jun 01 20:46:06 2010
    Info: Processing ended: Tue Jun 01 20:46:06 2010
    ~/Downloads
    OK
    Downloaded 3643KB in 0.7s (5204.2KB/s)
    Verified OK
    3 [sig] nios2-gdb-server 2516 c:\altera\91\nios2eds\bin\nios2-gdb-server.exe: *** fatal error - called with threadlist_ix -1
    /cygdrive/c/altera/91/nios2eds/bin/nios2-download: line 595: 2516 Hangup nios2-gdb-server --go --tcpport none --write-pid ./nios2-download.pid ./zImage.initramfs.gz.srec
    altera usb-blaster + linux.initramfs.gz
    in .
    embraer_top.sof
    Info: Started Programmer operation at Tue Jun 01 20:45:35 2010
    Info: Ended Programmer operation at Tue Jun 01 20:45:36 2010
    Info: Processing ended: Tue Jun 01 20:45:36 2010
    Info: Elapsed time: 00:00:04
    ~/Downloads
    OK
    Verified OK
    3 [sig] nios2-gdb-server 4736 c:\altera\91\nios2eds\bin\nios2-gdb-server.exe: *** fatal error - called with threadlist_ix -1
    /cygdrive/c/altera/91/nios2eds/bin/nios2-download: line 595: 4736 Hangup nios2-gdb-server --go --tcpport none --write-pid ./nios2-download.pid ./linux.initramfs.gz.srec
    Now we have two issues,
    1. the usb blaster, please check if your jtag has proper termination.
    2. shell in the image, please make clean, use default configuration and make again.
    - Hippo
