16 years agoDownload image ok, but boot fail
Hi Guys, I need help... maybe someone have passed for this trouble. I try to run Linux on Nios II, obviously. My project is based on DE2_NET. Now I used a CYCLONE II EP2C8F256C8 in a cu...
16 years agoHi Hippo,
Good tip... Now, I changed the onchip_memory2_0.S1 and onchip_memory2_0.S2 to same address (0x08000800). Well, I got two results because I ran with two USB-Blaster cable. One is a original ALTERA USB-Blaster cable (rev c) and other is a CUSTOM USB-Blaster cable (probably based on rev. A). Bellow I print the results for each case. Sorry for so much information. ------------------------------------------------------------------------------------------------------------ custom usb-blaster cable + linux.initramfs.gz[NiosII EDS]$ nios2-configure-sof embraer_top.sof Searching for SOF file: in . embraer_top.sof Info: ******************************************************************* Info: Running Quartus II Programmer Info: Command: quartus_pgm --no_banner --mode=jtag -o p;embraer_top.sof Info: Using programming cable "USB-Blaster [USB-0]" Info: Started Programmer operation at Tue Jun 01 20:47:24 2010 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x020B20DD Info: Configuration succeeded -- 1 device(s) configured Info: Successfully performed operation(s) Info: Ended Programmer operation at Tue Jun 01 20:47:25 2010 Info: Quartus II Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 89 megabytes Info: Processing ended: Tue Jun 01 20:47:25 2010 Info: Elapsed time: 00:00:02 Info: Total CPU time (on all processors): 00:00:00 ~/Downloads [NiosII EDS]$ nios2-download -g linux.initramfs.gz Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 4845KB in 84.7s (57.2KB/s) Verified OK Starting processor at address 0xC2000000 ~/Downloads [NiosII EDS]$ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios nios2-terminal: II systems. You may experience intermittent JTAG communication nios2-terminal: failures with this cable. Please use a USB Blaster revision B nios2-terminal: cable or another supported cable. Please refer to the file nios2-terminal: errata.txt included in the Nios II development kit documents nios2-terminal: directory for more information. nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Linux version 2.6.30-00494-g84a224b-dirty (tcb@vostromdv) (gcc veLinux version 2.6.30-00514-ge7e25ac-dirty (tcb@vostromdv) (gcc version 4.1.2)# 4 Mon May 31 23:02:17 BRT 2010 console [early0] enabled Early printk initialized Linux/Nios II-MMU init_bootmem_node(?,0x24d3, 0x2000, 0x3000) free_bootmem(0x24d3000, 0xb2d000) reserve_bootmem(0x24d3000, 0x200) Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4064 Kernel command line: NR_IRQS:32 PID hash table entries: 64 (order: 6, 256 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) We have 12288 pages of RAM Memory available: 11288k/4937k RAM, 0k/0k ROM (1728k kernel code, 3209k data) Calibrating delay loop... 49.35 BogoMIPS (lpj=246784) Mount-cache hash table entries: 512 net_namespace: 296 bytes NET: Registered protocol family 16 init_BSP(): registering device resources bio: create slab <bio-0> at 0 NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 512 (order: 0, 4096 bytes) TCP bind hash table entries: 512 (order: -1, 2048 bytes) TCP: Hash tables configured (established 512 bind 512) TCP reno registered NET: Registered protocol family 1 msgmni has been set to 22 io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered (default) ttyJ0 at MMIO 0x8004d50 (irq = 1) is a Altera JTAG UART console handover: boot [early0] -> real [ttyJ0] mice: PS/2 mouse device common for all mice TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. sh invoked oom-killer: gfp_mask=0xd0, order=1, oomkilladj=0 Stack from c293ce2c:<0> <0> 000000d0<0> c2044da4<0> 00000000<0> c24c8e80<0> 000000d0<0> 00000001<0> c202beac<0> c2541c20<0> <0> 00000000<0> c2209170<0> c2541c20<0> c2209170<0> c20451ac<0> 00000000<0> c21e2518<0> 00000007<0> <0> 0baff100<0> 000000d0<0> 00000001<0> 000000d0<0> 00000001<0> c22155e4<0> 00000000<0> 00000000<0> <0> c20452a0<0> 00000000<0> 00000000<0> c2541c20<0> c2048560<0> 00000001<0> 00000048<0> 00000000<0> <0> 00000000<0> 00000000<0> 00000042<0> 00000000<0> 00000001<0> 00000010<0> 000200d0<0> 00000001<0> <0> 00000000<0> 00000000<0> c24c308c<0> c2541c20<0> 01200011<0> c254b680<0> 00000000<0> 2ac06048<0> Call Trace:<0> <0> [<c20486ac>]<0> [<c200e1e4>]<0> [<c201f808>]<0> [<c200f1c0>]<0> <0> [<c200afd0>]<0> [<c20023b4>]<0> [<c2000cf8>]<0> [<c2000888>]<0> Mem-Info: DMA per-cpu: CPU 0: hi: 0, btch: 1 usd: 0 Active_anon:12 active_file:0 inactive_anon:32 inactive_file:0 unevictable:1794 dirty:0 writeback:0 unstable:0 free:657 slab:280 mapped:151 pagetables:8 bounce:0 DMA free:2628kB min:4096kB low:5120kB high:6144kB active_anon:48kB inactive_anon:128kB active_file:0kB inactive_file:0kB unevictable:7176kB present:16256kB pages_scanned:0 all_unreclaimable? no lowmem_reserve[]: 0 0 0 DMA: 3*4kB 3*8kB 2*16kB 0*32kB 0*64kB 0*128kB 0*256kB 1*512kB 0*1024kB 1*2048kB 0*4096kB = 2628kB 1794 total pagecache pages 4096 pages RAM 1274 pages reserved 226 pages shared 1972 pages non-shared Out of memory: kill process 587 (sh) score 30 or a child Killed process 587 (sh) Kernel panic - not syncing: Out of memory and no killable processes...
