16 years agoDownload image ok, but boot fail
Hi Guys, I need help... maybe someone have passed for this trouble. I try to run Linux on Nios II, obviously. My project is based on DE2_NET. Now I used a CYCLONE II EP2C8F256C8 in a cu...
16 years agocont...
----------------------------------------------------------------------------------------------------- altera usb-blaster + zimage.initramfs.gz [NiosII EDS]$ nios2-configure-sof embraer_top.sof Searching for SOF file: in . embraer_top.sof Info: ******************************************************************* Info: Running Quartus II Programmer Info: Command: quartus_pgm --no_banner --mode=jtag -o p;embraer_top.sof Info: Using programming cable "USB-Blaster [USB-0]" Info: Started Programmer operation at Tue Jun 01 20:46:05 2010 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x020B20DD Info: Configuration succeeded -- 1 device(s) configured Info: Successfully performed operation(s) Info: Ended Programmer operation at Tue Jun 01 20:46:06 2010 Info: Quartus II Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 89 megabytes Info: Processing ended: Tue Jun 01 20:46:06 2010 Info: Elapsed time: 00:00:02 Info: Total CPU time (on all processors): 00:00:00 ~/Downloads [NiosII EDS]$ nios2-download -g zImage.initramfs.gz Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 3643KB in 0.7s (5204.2KB/s) Verified OK Starting processor at address 0xC2500000 assertion "m_state == STATE_DEBUG" failed: file "nios2debug.cpp", line 562 3 [sig] nios2-gdb-server 2516 c:\altera\91\nios2eds\bin\nios2-gdb-server.exe: *** fatal error - called with threadlist_ix -1 /cygdrive/c/altera/91/nios2eds/bin/nios2-download: line 595: 2516 Hangup nios2-gdb-server --go --tcpport none --write-pid ./nios2-download.pid ./zImage.initramfs.gz.srec ------------------------------------------------------------------------------------------------------ altera usb-blaster + linux.initramfs.gz [NiosII EDS]$ nios2-configure-sof embraer_top.sof Searching for SOF file: in . embraer_top.sof Info: ******************************************************************* Info: Running Quartus II Programmer Info: Command: quartus_pgm --no_banner --mode=jtag -o p;embraer_top.sof Info: Using programming cable "USB-Blaster [USB-0]" Info: Started Programmer operation at Tue Jun 01 20:45:35 2010 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x020B20DD Info: Configuration succeeded -- 1 device(s) configured Info: Successfully performed operation(s) Info: Ended Programmer operation at Tue Jun 01 20:45:36 2010 Info: Quartus II Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 89 megabytes Info: Processing ended: Tue Jun 01 20:45:36 2010 Info: Elapsed time: 00:00:04 Info: Total CPU time (on all processors): 00:00:00 ~/Downloads [NiosII EDS]$ nios2-download -g linux.initramfs.gz Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 4845KB in 0.8s (6056.2KB/s) Verified OK Starting processor at address 0xC2000000 assertion "m_state == STATE_DEBUG" failed: file "nios2debug.cpp", line 562 3 [sig] nios2-gdb-server 4736 c:\altera\91\nios2eds\bin\nios2-gdb-server.exe: *** fatal error - called with threadlist_ix -1 /cygdrive/c/altera/91/nios2eds/bin/nios2-download: line 595: 4736 Hangup nios2-gdb-server --go --tcpport none --write-pid ./nios2-download.pid ./linux.initramfs.gz.srec
