21 years agoDoes a NIOS II need reset?
Folks,
I recently began porting my NIOS II design to its final hardware platform from the 1C20 eval board. During this effort, I eliminated reset by assigning it internally to '0'. My logic uses active high-reset so all the reset logic and routing disappeared. The NIOS II uses active low reset so its reset is inverted before entering the NIOS II component. When reset is set '0' (inactive), the NIOS II core did not boot. I tested this by supplying reset only to the NIOS II component. When I did this, the NIOS II booted normally (all this testing done on the 1C20 eval bd). Does the NIOS II core need a reset? I thought I got one for "free" when the device configured.
