20 years ago
DE2 with dm9000 compiled error!! help
HI :hippo
I add TPC/IP protocol in the kernel my board is DE2,the network card is dm9000.when compile the kernel,the error messares were found:
drivers/net/dm9000x.c:305: error: `na_dm9000_irq' undeclared here (not in a function)
drivers/net/dm9000x.c: In function `dmfe_probe':
drivers/net/dm9000x.c:362: error: `na_dm9000' undeclared (first use in this function)
drivers/net/dm9000x.c:362: error: (Each undeclared identifier is reported only once
drivers/net/dm9000x.c:362: error: for each function it appears in.)
drivers/net/dm9000x.c: At top level:
drivers/net/dm9000x.c:291: warning: 'dmfe_debug' defined but not used
drivers/net/dm9000x.c:295: warning: 'debug' defined but not used
drivers/net/dm9000x.c:296: warning: 'mode' defined but not used
drivers/net/dm9000x.c:785: warning: 'dmfe_reset_dm9000' defined but not used
make[2]: *** [drivers/net/dm9000x.o] error 1
make[1]: *** [drivers/net] error 2
make: *** [drivers] error 2
how can I do now????
    check your kernel include/nios2_system.h
    it is na_DM9000A ,
    edit drivers/net/dm9000x.c na_dm9000 => na_DM9000A
    --- Quote Start ---
    it is na_dm9000a ,
    edit drivers/net/dm9000x.c na_dm9000 => na_dm9000a
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15897)
    --- quote end ---
    --- Quote End ---
    I&#39;m getting the exact same errors, except drivers/net/dm9000x.c doesn&#39;t exist. I&#39;m pretty sure I&#39;ve followed the config steps in the nioswiki to the letter. Copying the file from the nios kit directory doesn&#39;t work. What can I do?
    Are you using uClinux-dist?
    The ptf for vendor_hwselect must match your board and the sof.
    If you use DE2, look in DE2_System/DE2_demonstrations/DE2_NET/ nios_0.ptf and DE2_NET.sof .
    If you use DE2 board, you should enable "DM9000A with checksum offloading" . linux-2.6.x/drivers/net/dm9ks.c .
    --- Quote Start ---
    originally posted by hippo@Feb 8 2007, 09:59 PM
    are you using uclinux-dist?
    the ptf for vendor_hwselect must match your board and the sof.
    if you use de2, look in de2_system/de2_demonstrations/de2_net/ nios_0.ptf and de2_net.sof .
    if you use de2 board, you should enable "dm9000a with checksum offloading" . linux-2.6.x/drivers/net/dm9ks.c .
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=21385)
    --- quote end ---
    --- Quote End ---
    Thanks for the reply. I&#39;m sorry for the delay in mine - I&#39;ve had to put this project aside for a few days.
    Anyway, I&#39;m using the microtronix 1.4 distro (2.6.11) so my kernel config calls it "Davicom DM9000 10_100 chip support" and it&#39;s checked. Is that going to be a problem?
    Sorry, I won&#39;t support the Microtronix&#39;s release 1.4 or Windows.
    I will support uClinux-dist only.
