20 years agoDE2 with dm9000 compiled error!! help
HI :hippo I add TPC/IP protocol in the kernel my board is DE2,the network card is dm9000.when compile the kernel,the error messares were found: drivers/net/dm9000x.c:305: error: `na_dm9000_ir...
19 years ago --- Quote Start --- originally posted by hippo@Feb 8 2007, 09:59 PM are you using uclinux-dist?
the ptf for vendor_hwselect must match your board and the sof.
if you use de2, look in de2_system/de2_demonstrations/de2_net/ nios_0.ptf and de2_net.sof .
if you use de2 board, you should enable "dm9000a with checksum offloading" . linux-2.6.x/drivers/net/dm9ks.c .
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21385)
--- quote end ---
--- Quote End --- Thanks for the reply. I'm sorry for the delay in mine - I've had to put this project aside for a few days. Anyway, I'm using the microtronix 1.4 distro (2.6.11) so my kernel config calls it "Davicom DM9000 10_100 chip support" and it's checked. Is that going to be a problem?
