20 years agoDE2 with dm9000 compiled error!! help
HI :hippo I add TPC/IP protocol in the kernel my board is DE2,the network card is dm9000.when compile the kernel,the error messares were found: drivers/net/dm9000x.c:305: error: `na_dm9000_ir...
19 years agoAre you using uClinux-dist?
The ptf for vendor_hwselect must match your board and the sof. If you use DE2, look in DE2_System/DE2_demonstrations/DE2_NET/ nios_0.ptf and DE2_NET.sof . If you use DE2 board, you should enable "DM9000A with checksum offloading" . linux-2.6.x/drivers/net/dm9ks.c .
