14 years agoDDR SDRAM won't fit!
Hi All,
I am using a cyclone III starter kit, which has the EP3C25F324C6 FPGA on and the zentel A3S56D40ETP-G5 SD-RAM. I have (i think) added the DDR ram controller in QSYS correctly (I used the information in the system architect design tutorial, which I appreciate s for the NEEK). I then generated the system and all is OK, no warnings and no errors. I then dropped this into a quartus schematic, connected all the IO to the outputs and bidirectionals. I then did analysis and elaboration which went OK but when I try to compile the project i get some nasty erros the chief of which are: Error (171000): Can't fit design in device. I find this hard to believe as there is nothing else in the system to speak of! also I get: Error (165024): The DQ group with DQS pin "MEMDQS[1]" has invalid DQ group assignements. Error (165024): The DQ group with DQS pin "MEMDQS[0]" has invalid DQ group assignements. I am a little puzzled to say the least. If someone could shed some light on this for me I would be most grateful. D7 Replies
When You generate DDR controller, the core also generates a TCL script. Run it.
Hi Socrates,
There seem to be quite a lot of TCL scripts generated that are related to the SDRAM, some are in the synthesis/submodules folder and some are in the project folder. Which are you referring to? and what do you mean by run it! thanks for taking the time to help. D - Altera_Forum
In Quartus: Tools -> TCL Scripts.
Woohoo, it's alive!
It appears I had two instances of the ALTMEMPHY trying to fit into the FPGA, quite how that happened I don't know but it became apparent when I looked at the TCL file you suggested and saw two lots of differently named tcl scripts. So I rebuilt everything and tried again and it worked. I know have a simple program running from the SDRAM so thank you SOcrates. D - Altera_Forum
Hi All,
I am using a cyclone III starter kit, which has the EP3C25F324C6 FPGA on and the zentel A3S56D40ETP-G5 SD-RAM. I have (i think) added the DDR ram controller in QSYS correctly (I used the information in the system architect design tutorial, which I appreciate s for the NEEK). I then generated the system and all is OK, no warnings and no errors. I then dropped this into a quartus schematic, connected all the IO to the outputs and bidirectionals. I then did analysis and elaboration which went OK but when I try to compile the project i get some nasty erros the chief of which are: Error (171000): Can't fit design in device. I find this hard to believe as there is nothing else in the system to speak of! also I get: Error (165024): The DQ group with DQS pin "MEMDQS[1]" has invalid DQ group assignements. Error (165024): The DQ group with DQS pin "MEMDQS[0]" has invalid DQ group assignements. I am a little puzzled to say the least. If someone could shed some light on this for me I would be most grateful. D - Altera_Forum
--- Quote Start --- When You generate DDR controller, the core also generates a TCL script. Run it. --- Quote End --- Hi Socrates, I have an issue with fitting DDR SDRAM controller on Cyclone III (3C120). I am building a triple-speed Ethernet module using Qsys as per the altera example http://www.altera.com/support/examples/nios2/exm-tse-sgdma.html?gsa_pos=1&wt.oss_r=1&wt.oss=triple speed ethernet 13.1 When I try to build my project in Quartus II, I see the following errors: Error (165011): altmemphy pin placement was unsuccessful Error (165024): The DQ group with DQS pin "mem_dqs_to_and_from_the_ddr2_bot[0]" has invalid DQ group assignments .. Error (171000): Can't fit design in device Prior to compiling my design, I had run the TCL script, generated by the Qsys. But still, the fitting error persists. And, I do not see multiple instance of any design component in my top module. Also, I've a query regarding any modification that is required to the TCL script, before I run it? Thank you very much. - Altera_Forum
I was able to fix this issue by modifying the pin assignments. (ex: mem_dqs_to_and_from_the_ddr2_bot[0] set to SSTL-18 class I (as suggested in the flow messages )) and by back annotating the pin assignments made during the compilation phase.
