14 years agoDDR SDRAM won't fit!
Hi All, I am using a cyclone III starter kit, which has the EP3C25F324C6 FPGA on and the zentel A3S56D40ETP-G5 SD-RAM. I have (i think) added the DDR ram controller in QSYS correctly (I used ...
12 years agoHi All,
I am using a cyclone III starter kit, which has the EP3C25F324C6 FPGA on and the zentel A3S56D40ETP-G5 SD-RAM. I have (i think) added the DDR ram controller in QSYS correctly (I used the information in the system architect design tutorial, which I appreciate s for the NEEK). I then generated the system and all is OK, no warnings and no errors. I then dropped this into a quartus schematic, connected all the IO to the outputs and bidirectionals. I then did analysis and elaboration which went OK but when I try to compile the project i get some nasty erros the chief of which are: Error (171000): Can't fit design in device. I find this hard to believe as there is nothing else in the system to speak of! also I get: Error (165024): The DQ group with DQS pin "MEMDQS[1]" has invalid DQ group assignements. Error (165024): The DQ group with DQS pin "MEMDQS[0]" has invalid DQ group assignements. I am a little puzzled to say the least. If someone could shed some light on this for me I would be most grateful. D
