14 years agoDDR SDRAM won't fit!
Hi All, I am using a cyclone III starter kit, which has the EP3C25F324C6 FPGA on and the zentel A3S56D40ETP-G5 SD-RAM. I have (i think) added the DDR ram controller in QSYS correctly (I used ...
14 years agoWoohoo, it's alive!
It appears I had two instances of the ALTMEMPHY trying to fit into the FPGA, quite how that happened I don't know but it became apparent when I looked at the TCL file you suggested and saw two lots of differently named tcl scripts. So I rebuilt everything and tried again and it worked. I know have a simple program running from the SDRAM so thank you SOcrates. D
