14 years agoDDR SDRAM won't fit!
Hi All, I am using a cyclone III starter kit, which has the EP3C25F324C6 FPGA on and the zentel A3S56D40ETP-G5 SD-RAM. I have (i think) added the DDR ram controller in QSYS correctly (I used ...
12 years ago --- Quote Start --- When You generate DDR controller, the core also generates a TCL script. Run it. --- Quote End --- Hi Socrates, I have an issue with fitting DDR SDRAM controller on Cyclone III (3C120). I am building a triple-speed Ethernet module using Qsys as per the altera example http://www.altera.com/support/examples/nios2/exm-tse-sgdma.html?gsa_pos=1&wt.oss_r=1&wt.oss=triple speed ethernet 13.1 When I try to build my project in Quartus II, I see the following errors: Error (165011): altmemphy pin placement was unsuccessful Error (165024): The DQ group with DQS pin "mem_dqs_to_and_from_the_ddr2_bot[0]" has invalid DQ group assignments .. Error (171000): Can't fit design in device Prior to compiling my design, I had run the TCL script, generated by the Qsys. But still, the fitting error persists. And, I do not see multiple instance of any design component in my top module. Also, I've a query regarding any modification that is required to the TCL script, before I run it? Thank you very much.
