10 years ago
Data transfer from hardware Modules to Nios
As I have described in a previous post http://www.alteraforum.com/forum/showthread.php?t=52808&p=217155&highlight=#post217155 I want to implement a DAQ system using NIOS and W5300. The communication problem between NIOS and W5300 has been solved and I am able now to transfer data through TCP/IP. Now I am dealing with a different problem that has to do with transfer data between hardware module (implemented in verilog) and NIOS.
To give you a short description my system consists of 36 hardware modules each of them transferring 64 bits of data every 462us. The goal is to grab this data and send them through Ethernet to a pc, so my required data rate is about 5 Mbits/s. Ethernet communication itself doesn't seem to be a problem cause can achieve much higher speeds. The problem is how fast the cpu grabs the data for the modules. In the beginning I thought using just PIOs wouldn't be a problem. So NIOS collects the data from the modules and then transfer them again to W5300 fifo, but using counters I found that my maximum data rate is only about 4Mbit/s. Is there any alternative way to go? I thought using DMA but it sounds bit complicated for me at the moment and I don't know if at the end would be enough.
Any suggestions??
