10 years agoData transfer from hardware Modules to Nios
Hello, As I have described in a previous post http://www.alteraforum.com/forum/showthread.php?t=52808&p=217155&highlight=#post217155 I want to implement a DAQ system using NIOS and W5300. The c...
10 years agoThank you very much, actually you are right. I used timestamp timer and the total time for PIO reads was about 4us. So the problem is withe the cpu-w5300 communication. I used the drivers provided by Wiznet and the code isn't so complicated. On the other hand I am using generic tristate controller in QSYS to connect W5300 to Nios, so there is maybe a problem withe the configuration of tristate controller. Attached is the timing I used (I am running with a 140 Mhz clk). Do you have any experience with this?
https://www.alteraforum.com/forum/attachment.php?attachmentid=12555
