10 years agoData transfer from hardware Modules to Nios
Hello, As I have described in a previous post http://www.alteraforum.com/forum/showthread.php?t=52808&p=217155&highlight=#post217155 I want to implement a DAQ system using NIOS and W5300. The c...
10 years agoThe forum shrunk your picture, so it's not very readable. I did notice that your specifying your timing in terms of "cycles", meaning your 140MHz clock, and that your "Read wait time" was double digit [14? 24?]. The W5300 datasheet says tRD = 65ns so 9.1 cycles [round up to 10]. And turnaround time is even larger? (shouldn't be?)
This is just one example, but I personally find it more intuitive to use "nanoseconds" and then just plugin the values from the datasheet table just as you read them, and let Qsys handle the rounding. After you've done all that, will you see a dramatic increase? It's hard to say without knowing what percentage of your time is actually spent reading, writing to the external device. Other sources of bottleneck could be basic things like running with no cache from a slow memory, for example. It could also be something like you're taking source code for another environment, and then missed some porting detail like how time is managed if there is any sort of internal delay in your ported code. Anyway, I would drill down one more level into the W5300 code and profile the time used by the register read/write primitives to identify if your problem is there or not. If a big percentage of your time is with that I/O, yes focus on the tri-state bridge configuration.
