10 years agoData transfer from hardware Modules to Nios
Hello, As I have described in a previous post http://www.alteraforum.com/forum/showthread.php?t=52808&p=217155&highlight=#post217155 I want to implement a DAQ system using NIOS and W5300. The c...
10 years agoCouple of things:
send() and wiz_write_buf() appear to work off of lengths in units of 16-bit words, not bytes. Your test_tcps() is saying send 32 of them but I think you only need 16? Then, your wiz_write_buf() taking 35us means >1us per each of your (32) writes that you are doing. I would quickly try some things like at least turning on the compiler optimization and maybe inlining the wiz_write_buf() loop and function calls, to try to reduce the loop overhead. Even with a conservative budget of 250ns per write taken by the tri-state timing, you're losing 3x that (another 750ns) on loop overhead. NIOS isn't a great performer, but I think you should be able to manage better than that.
