21 years agoCOSIM: Internal Error (unhandled exception)
COSIM: Internal Error (unhandled exception) in file cosim_main.cpp at line 132.
try to run as NIOS II ISS. No idea. What could be the reason ? Thanks OK. Solved.5 Replies
Did you solve this problem? because I have the same problem, If you did, could you explain it to me?
Thank you - Altera_Forum
Please i have the same problem.I can't solve it.
If you did it give me the solution.:confused: - Altera_Forum
Hi farhaenis;
do you run you program with run as hardware or with ISS? - Altera_Forum
i run it as ISS
if it runs as ISS, you have to make sure to choose this path in the first window for SOPC builder system PTF File
C:\altera\80\nios2eds\examples\verilog\niosII_cycloneII_2c35\standard\NiosII_cycloneII_2c35_standard_sopc.ptf it shouldn't have any error then
