21 years agoCOSIM: Internal Error (unhandled exception)
COSIM: Internal Error (unhandled exception) in file cosim_main.cpp at line 132. try to run as NIOS II ISS. No idea. What could be the reason ? Thanks OK. Solved.
16 years agoPlease i have the same problem.I can't solve it.
If you did it give me the solution.:confused:
