21 years agoCOSIM: Internal Error (unhandled exception)
COSIM: Internal Error (unhandled exception) in file cosim_main.cpp at line 132. try to run as NIOS II ISS. No idea. What could be the reason ? Thanks OK. Solved.
16 years agoDid you solve this problem? because I have the same problem, If you did, could you explain it to me?
Thank you
