19 years agoconfiguration controller in custom board
Hi! Everyone!
Is it necessary to design configuration controller in custom board? If it just give stablity to system, is it mandatory or optional? Thanks! Regards http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif6 Replies
OK, what exactly do you mean by configuration controller? EPCS?
IzI - Altera_Forum
If you want the board/system to boot into a functional state then, yes, some sort of config controller (EPCS, EPC, etc.) is necessary.
--- Quote Start --- originally posted by iztok.jeras@Jan 26 2007, 09:14 PM ok, what exactly do you mean by configuration controller? epcs?izi
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20895)
--- quote end ---
--- Quote End --- Yeb, EPCS! But I wondered that controller is necessary when I use CFI. Using CFI, controller is unnecessary. thanks! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
--- Quote Start --- originally posted by slacker@Jan 27 2007, 01:37 AM if you want the board/system to boot into a functional state then, yes, some sort of config controller (epcs, epc, etc.) is necessary.<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20905)
--- quote end ---
--- Quote End --- Oh my 'nios' GOD. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif Thanks! very helpful!
--- Quote Start --- originally posted by jaeper+jan 28 2007, 05:27 pm--><div class='quotetop'>quote (jaeper @ jan 28 2007, 05:27 pm)</div>--- quote start ---
<!--quotebegin-slacker@Jan 27 2007, 01:37 AM if you want the board/system to boot into a functional state then, yes, some sort of config controller (epcs, epc, etc.) is necessary.
--- quote end ---
--- Quote End --- Oh my 'nios' GOD. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif Thanks! very helpful! <div align='right'><{post_snapback}> (index.php?act=findpost&pid=20972)</div> [/b] --- Quote End --- Please keep in mind that you still need to load a hardware image from that CFI flash into your FPGA on power up. For that, you'll likely need a PLD. A lot of the Nios II Altera development kits use a "Max + Flash" combination and the config controller design is shipped with the Nios II EDS. I recommend this solution highly... Cheers, - slacker
If you are going for a simple and cheap solution than using only an serial SPI flash (EPCS) is better.
The epcs can hold both the hardware configuration image and the software. A parallel flash would be needed, if you need a very high read speed, or very large amounts of flash. EPCS and other SPI flash chips - sizes from 1Mbit to 64Mbit (usualy op to 512kB are used for the hardware image, the rest can be used for software and flash file systems) - read speed of 1MB/s is easily achievable IzI
