19 years agoconfiguration controller in custom board
Hi! Everyone! Is it necessary to design configuration controller in custom board? If it just give stablity to system, is it mandatory or optional? Thanks! Regards http://forum.ni...
19 years agoIf you are going for a simple and cheap solution than using only an serial SPI flash (EPCS) is better.
The epcs can hold both the hardware configuration image and the software. A parallel flash would be needed, if you need a very high read speed, or very large amounts of flash. EPCS and other SPI flash chips - sizes from 1Mbit to 64Mbit (usualy op to 512kB are used for the hardware image, the rest can be used for software and flash file systems) - read speed of 1MB/s is easily achievable IzI
